AndrewGT
Gearbox types Mk1 Cortina
Bit confused. Could someone please simply describe the types of box fitted to the Cortina Mk1?
I have heard 3 rail, then I have read 2000E then I have read that a 2000E is a 3 rail!!!!
Did the 1200 and 1500 use the same box? Was the GT box different (ratios??)
Is the Cortina Mk1 box the same as an Anglia 105E box?
Many thanks!!!
Yes , its a minefield but basically , the cars you have listed all use a variation of the 3 rail box which only refers to 3 selector rails in the top of the box . Difference can be tailshaft , where the gearstick mounts etc but the main body of the box is the same but as you say , ratios are different >
