kevinsingh
Horn positions
Evenin All…. Warm night :cool:
My work in progress MK5 has some sort of alarm rigged up to the headlamps and fuel flap…
No idea how it works nor do I have a fob..!,
The alarm box is sighted on the near side front inner wing more or less in line with the battery..
The horns are positioned in the same inner wing very near the scuttle …
I would like to ask if anyone can here is the correct position for the two horns under the bonnet as I want the under bonnet to look original.
Not sure how to remove the alarm but either side of the radiator there are two wires with bullet type ends on them leading to this alarm box..
Do the horns sit near the radiator or under the front panel..?.
Much appreciate any pointers   And as usual  thank you in advance…
regards
Kevin
They go between the front grille & radiator, you should see a mount with an M8 captive nut they both go there.
