Beeper
Sender unit question.
A few months back I eventually got around to fitting the petrol tank I bought from Sheff-Cort-Cent a couple of years back (I think)! On refitting the sender unit I found the metal pipe to be loose. Not wobbling around loose but loose enough for it to turn and probably leak. Any ideas on what I could use to tighten it up and seal it again?
Hi Beeper, Give the joint a really good clean off on both sides and have a go at soldering it. Use a gas torch rather than a soildering iron. Obviously with the sender unit out of the tank !!
Steve
Edited by Steve Walton
Spelling!
But will solder take to alloy?
one way to find out
Both parts are steel.
