KKCortina 2 Posted September 1, 2021 Guys I am changing Upper and Lower Ball Joints in my early'72 Cortina....... they are the originals and so have the domed rivets fitted.....and the replacements have the usual nut/bolt included to replace the rivets What is the best way to cleanly remove the domed rivets other than to use a hand grinder which will more than likely damage the surrounding area with grinder marks/scars etc.......is a pillar drill in combination with a vice of some sort the answer? Suggestions invited from those who have carried out this task before............ Quote Share this post Link to post Share on other sites
dgo 66 Posted September 1, 2021 (edited) I drilled the ones out on my Mk4. I used an undersized drill bit to avoid drilling into the arm itself then sliced the end off the rivet with a cold chisel I drilled from the flat end rather than trying to drill from the domed side Edited September 1, 2021 by dgo Quote Share this post Link to post Share on other sites
RichardJ 58 Posted September 1, 2021 ^whs I did the same, but used a number of drill bits of increasing size until the rivet was only held together by sliver of metal and could then just be punched through the arm. If you have taken the whole arm off the car it's quite easy to do. Make sure you give it a nice sharp whack with a centre punch first to keep the drill from wondering, though. Quote Share this post Link to post Share on other sites
KKCortina 2 Posted September 1, 2021 Great advice there lads ....will try as both upper and lower arms are off the car .....thanks again .... KK Quote Share this post Link to post Share on other sites
TIB3300 389 Posted September 2, 2021 (edited) Just grind it on the old ball joint face side Edited September 2, 2021 by TIB3300 Quote Share this post Link to post Share on other sites
dgo 66 Posted September 2, 2021 10 hours ago, KKCortina said: Great advice there lads ....will try as both upper and lower arms are off the car .....thanks again .... KK While they're off the car do the bushes if you're not already planning that Quote Share this post Link to post Share on other sites
KKCortina 2 Posted September 6, 2021 Thanks TIB3000 - Never thought of that method! Will try...... Also DGO - plan to do the bushings - have the old ones out and ready to press in the new ones.... Quote Share this post Link to post Share on other sites
mike1968uk 0 Posted July 16, 2022 I used a dremel made a few crosses on the rivets and chiselled them off Quote Share this post Link to post Share on other sites
