bugsntinas
Hazards.
Well the hazards were working then the stopped, flashed once then stopped altogether. The indicators work fine. Tried a spare switch nothing, bought a zwitch from craig, thanks by tbe way, but tbey still don't work. I assume 3 switches all can't be fault so what else should i check oh and there is poeer to the switch as tested that
Had this before seem to recall something with the indicator stalk not reconnecting the circuit when off this allowing the hazards to work.
 I'll have a poke around and see whats what. I'll swap over the stalk to
