RoyB
Front wall plug black/gray
Hi guys. Are the front wall plug removable? Can i separate the loom here? Thanks.
If you mean the 2 round ones on drivers side of bulkhead on a MK3/4/5/P100 then yes.
The engine bay side also locates them, they can be a buger to refit a squirt of your favourite lube (ooh matron) helps.
Thanks for the reply. Is it twist and pull or just pull?
They should pull out, like large plastic grommets.
As above
