Cortina1975
Cortina 1600 - coolant leak
Hi , trying to get a few jobs done on the Cortina
Have a water leak around the front pulley that's been getting steadily worse.
Noticed there is  quite a bit of water coming out the exhaust..hoping it's just condensation from all the stop starts and not something serious like a cracked block or problem with the unleaded valve seats.:headscratch:. Car has been stood for decades previously so could be frost damaged for all i know.. Has done 65k miles and compressions are 185 -190 on all cylinders so it's not in bad order except the water leaking issues.
Suspect the water pump but it's an almost brand new part from Burton Power. Have these been known to be faulty ?
Thanks all :cheers:
They've been selling slot of overpriced chinesium,is it leaking from the breather hole on the bottom of pump?
Thanks Sir Craig. :cheers:
Had a look under tonight and can't see anything coming out the hole so I guess the pump is okay ? . Took the fan and radiator out but still can't see where the leak  is coming from ..it's pooling around the crank pulley. Think the pump will have to come off next ..im wondering if the gasket has failed the bolts all seem pretty tight
Edited by Cortina1975
Could have shrunk due to long layup.
Use some black silicone specifically for water pumps etc, about £7.00 a small tube, I did the water pump on a Ducatti recently, didn't even have a gasket, just sealant made a water tight seal, l did leave it to cure for 24hrs before re filling with anti freeze.
Thanks chaps :cheers:
Replaced the pump gasket with one that was supposed to be for a Cosworth engine and no more leaks since.  Suspect the origonal gasket had shrunk  or just a poor quality Chinese copy.
Used a bit of the black gasket silicone too for belt and braces.  Need to get some anti freeze in now and flush the rust out.
