deltamal
Window winder
The drivers window winder on my Crusader shed some of its inner nylon teeth a few years ago, I got a second hand one but it was the same, would the offside rear gear be the same? if so I could swap them over as the rear does not get the same use....
Yes , you'll have to strip both mechanism's, rear have even less wear.
Thats good,  I have already stripped the front one down, do you have an offside rear winder mechanism spare?
Yep £20 Inc p&p
