Radders226 0 Posted June 9, 2022 Hi all, Since owning my Mk1 Cortina the rear brakes have a habit of sticking on after braking. I initially put it down to seized wheel cylinders and therefore have replaced them. However, to my disappointment, I still have the same problem. The pedal felt lovely after bleeding up, but has since returned to its 'hardness' during the test drive. The handbrake has always been very tight and only comes up 3 clicks before it locks the car solid. Could this be over adjusted? Or could it even be the after market remote servo that's fitted playing up? To give an example of how bad it it is, if I pull up at a junction with a slight hill, I don't have to worry about putting the handbrake on and the rear wheels are always hot when I arrive home. (only 3 mile test drives at the moment because of this issue) Anyone had these issues before? Share this post Link to post Share on other sites
sebspeed 23 Posted June 9, 2022 i would change the rear brake hose first as these can collapse inside and act as a one way valve. 1 Share this post Link to post Share on other sites
Radders226 0 Posted June 9, 2022 1 hour ago, sebspeed said: i would change the rear brake hose first as these can collapse inside and act as a one way valve. Would that also make it hard to bleed when doing the nearside rear? I had to really apply some pressure to get the fluid through. Share this post Link to post Share on other sites
Lotuscops 80 Posted June 9, 2022 I had this with my servo - is it a Girling Powerstop? To diagnose, just loop bypass the servo brake pipes and try it without. Share this post Link to post Share on other sites
Radders226 0 Posted June 9, 2022 1 hour ago, Lotuscops said: I had this with my servo - is it a Girling Powerstop? To diagnose, just loop bypass the servo brake pipes and try it without. I'm not sure, I've not had the car that long, so haven't really looked that closely at the servo. See uploaded pic Share this post Link to post Share on other sites
Radders226 0 Posted June 9, 2022 1 hour ago, Lotuscops said: I had this with my servo - is it a Girling Powerstop? To diagnose, just loop bypass the servo brake pipes and try it without. Looks more like this type? Share this post Link to post Share on other sites
Lotuscops 80 Posted June 10, 2022 Looks like a Lockheed type - still try the bypass test as I reckon it's that. Share this post Link to post Share on other sites
Radders226 0 Posted June 10, 2022 5 hours ago, Lotuscops said: Looks like a Lockheed type - still try the bypass test as I reckon it's that. It was the servo. I pulled the rubber hose off of the servo this morning and stuck a bolt in it to block it off, went for a short drive and hey presto! No more sticking brakes. Luckily, I had another one of those servos in my spares stash, so fitted that. All good again now. =) Share this post Link to post Share on other sites
Lotuscops 80 Posted June 13, 2022 On 6/10/2022 at 3:23 PM, Radders226 said: It was the servo. I pulled the rubber hose off of the servo this morning and stuck a bolt in it to block it off, went for a short drive and hey presto! No more sticking brakes. Luckily, I had another one of those servos in my spares stash, so fitted that. All good again now. =) That's good - more trouble than they are worth they are. Share this post Link to post Share on other sites
