wolfrace
Mk3 manual steering rack oil
Hello,
does anyone know the correct oil & quantity to use in the steering rack please?
thanks,
Rich
Hi,
     I use ATF Dextron 2 in my Power Rack. There should be a Dip Stick on the underside of the Pump Filler Cap. Rock the steering from side to side with the engine running to fill the rack and check the level with the engine off.
Steve
Cheers Steve but this is a manual rack, not a power rack, not even sure what the method for getting fluid into one is. Couldn’t find anything in the Haynes manual. I had to change the boots as they were past their best.
I don't have my mk3 manual to hand. If I remember right you need hypoid 75/90 or 80/90.
Hopefully Craig will drop by to confirm
Yes, it's gear oil. Not much though, 0.15 liters.
Yep just manual gearbox oil EP 75-90.
Thanks folks thats genuinely a big help. I couldn't find anything online.
I fitted another rack the other week but noticed a slight amount of play that i wasn't happy with so that came off, hopefully this one is ok, dont fancy £240 for a new one 😬
