C0RKTINA 107 Posted May 22, 2023 (edited) My folks. my mk5 main beams are not working, although the blue light on the dash is. Bulbs are OK. Is it likely to be the switch or the dip stick do you think? or something else. I think it's either the fourth or fifth fuse for main beam ... (had all the wrong fuses in it, mostly 25A, so I've changed them to 16/8/8/16/16/16/8 from left to right. I don't think that's a factor. Haynes manual has it all wrong I think.) Not urgent I don't go out in the dark anyway.... :-) Edited May 22, 2023 by norton gratuitous photo for no reason Quote Share this post Link to post Share on other sites
MK5dude 2 Posted May 22, 2023 Hi, did they ever work dude? If it helps, In Haynes manual it states there are four headlamp fuses located within a relay behind the windscreen washer reservoir. 1 - 16A L/H dipped Headlight 2 - 16A R/H dipped Headlight 3- 16A R/H main beam headlight and L/H aux light 4- 16A L/H main beam headlight and R/H aux light Quote Share this post Link to post Share on other sites
C0RKTINA 107 Posted May 22, 2023 Not sure, not had it long and don't go out at night so maybe not. Haynes manual is I'm sure wrong. It was only the Mk3 had the separate headlight fuses Quote Share this post Link to post Share on other sites
MK5dude 2 Posted May 22, 2023 Problem solved..... daytime driving only dude.... I hate electrics...I'm sure the guys/girls on here will be able to help further 1 Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 754 Posted May 22, 2023 Try wiggling/ cleaning the fuse nearest windscreen,also the plug underneath the fusebox my crayford does it especially if it's been stood. Quote Share this post Link to post Share on other sites
C0RKTINA 107 Posted May 22, 2023 OK Craig I will. I didn't think that fuse was Headlights though. (all fuses are brand new) Quote Share this post Link to post Share on other sites
C0RKTINA 107 Posted May 23, 2023 i see reading old topics that this is a common fault! Will check further later. Which fuse does what? I don't want to rely on Haynes ! Quote Share this post Link to post Share on other sites
C0RKTINA 107 Posted May 23, 2023 well with a bit of fiddling around and testing , they're now working. Main beam is fuse four and dip is five. Thanks for the replies Quote Share this post Link to post Share on other sites
TimB 102 Posted May 27, 2023 It's possible for what appears to be a good wiring connection is not. Corrosion can get inside the connectors, (especially on old cars) push on and even screwed fittings. If wiggling makes it work then the lasting repair is to take the connection off and clean both sides until they gleam then refit ensuring they are tight. Recurrent intermittent symptoms suggest this is the problem. Good you got it working but may reoccur. Change of subject - in your photo there is a beige estate, that yours too? Just interested as I have one too. Tim Quote Share this post Link to post Share on other sites
C0RKTINA 107 Posted May 29, 2023 it is mine but it's not an estate, (I can see how you might think so though, trick of the light...) Quote Share this post Link to post Share on other sites
