maurice 1 Posted May 30, 2023 Been a while since i went in to have a look at my Mk5 , thought id try to get her moved to a secure location, only one problem, i cannot get the steering lock off. The key goes in but will not turn to get the steering lock off. . I tried a few harsh movements with the steering wheel whilst trying to turn the key but to no avail. I had to pull her out of my garage and literally drag the car around with steel chains wrapped around the wheels and pull her with my Discovery to get her lined up with my newer secure garage. Any ideas how to undo the steering lock without having to damage it? I gave it a good squirt of penetrating oil down the keyhole and hope that may release it but any ideas will be appreciated Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 748 Posted May 31, 2023 Try waggling the key in all directions Inc in & out. If all else fails remove the complete housing & send it with key & I'll probably be able to sort it. Quote Share this post Link to post Share on other sites
maurice 1 Posted May 31, 2023 Cheers Craig I'll try that, if that doesn't work ill certainly remove it and bring it to you, be good to see you again been a few years Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 748 Posted May 31, 2023 No probs callers always welcome. Or bring to yat. Quote Share this post Link to post Share on other sites
maurice 1 Posted July 12, 2024 Problem solved, turned out i was using the wrong key 1 Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 748 Posted July 12, 2024 You stupid boy lol Quote Share this post Link to post Share on other sites
John Mack 331 Posted July 12, 2024 1 hour ago, maurice said: Problem solved, turned out i was using the wrong key Easy fix Quote Share this post Link to post Share on other sites
