AlanL 0 Posted June 14, 2023 Cortina Mk1 with early 1600 Kent crossflow , twin choke and single vacuum connection on the inlet manifold hi all Got my brakes all sorted with new 0.70" master and servo now fitted, The engine has the crank case breather can on the block which was plumbed to the vacuum take off point on the inlet under the carb, I used this spur for the servo and just fitted a little atmospheric filter on the crank case vent line in the interim. however I believe the crank case (PCV ?) need vacuum to operate and I may create ( more) oil leaks this may be a stupid question for the experts, but this is the advice I need Q:- can I simply "T" piece into the new servo line with the crank case line with 3/8" T piece and clamp there is a sweat around the oil filler cap ( escort type) so was thinking of getting the filler cap (Burton) with has the vent spur and plumbing it to the pancake air filter as well so crank case breathing venting info required innocently asking Alan Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 763 Posted June 14, 2023 Just use a T piece in the pipe, some had a T piece fitting in the manifold. Quote Share this post Link to post Share on other sites
AlanL 0 Posted June 14, 2023 Thank you for getting back to me I've just ordered a T piece so will splice that in ! what do you think about a vented pipe connection for the rocker cover I do get a mist over the cover, the O ring on the filler cap is good and no apparent drips from the current filler, just not sure if that would be just a sensible thing to do will try a latex glove over the filler neck to see if there is a blow first though Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 763 Posted June 14, 2023 Yes it needs vacuum so the leak is probably caused by the crankcase trying to vent past the cap. It should breathe through the cap but vent through the pipe into manifold & be re burnt, the pre-xflow vented to atmosphere & had no valve in the can/pipe. Quote Share this post Link to post Share on other sites
AlanL 0 Posted June 25, 2023 just a follow up yes "T" in place servo and crank case vent to single connection on manifold brakes all good and no oil leak or mist on the rocker cover, I say " sorted" thanks for the assistance Quote Share this post Link to post Share on other sites
