AlanL 0 Posted August 22, 2023 Folks I have a mk1 South African car which has an 8 gallon ( verified) tank but the sender is not the flat face and separate lock ring. My fuel sender attaches like the Mk2 one piece unit, the seal I removed was a simple neoprene/ rubber flat ring which destroyed itself. Searching, came across Mk2 owners club lists two sender unit types with pictures ( suggesting my one looks like the late Mk2 but no seals shown) could some body please show me the two types of seals? Mk2 club numbers are 2400E-9276B Aug 1969 onward and 113E 9276S ( which I think is the flat faced sender ring with the separate lock ring PM me if that's appropriate or alanlarnach@hotmail.com Oh the joys a SA car Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted August 22, 2023 It's the same as all 70's , even the transit van. Quote Share this post Link to post Share on other sites
AlanL 0 Posted August 22, 2023 so is that the one with the two compression lip seals on the inside ( almost like a V seal) Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted August 22, 2023 Yes that's it. Quote Share this post Link to post Share on other sites
AlanL 0 Posted August 23, 2023 ok ordered one ! thanks once again for helping me out ( great that you share your experience for the greater good) currently my sender is away for refurb so will try and get everything back together on its return thanks again # Alan Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted August 23, 2023 Always happy to help if I can. 1 Quote Share this post Link to post Share on other sites
RGD115 0 Posted April 2, 2024 On 8/22/2023 at 9:27 PM, sheffieldcortinacentre said: Yes that's it. i see you advised Alan L on his problem with his fuel sender seal i have a similar problem as i am replacing my fuel tank and upgrading my fuel line for ethanol resistant line could you advise me on is it importantence to fit a V seal or can it be a solid rubber one -- have been trying to find a viton seal but can't find to date or are the original seals ok don't want to fit something like nitrile if somewhere down the line it's going to break up/ leak ( mk 5 1982 cortina ) Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted April 2, 2024 No it can be a solid rubber ring, if you have a look through my posts of last year you'll see I had a bad leak from the sender seal on my MK3 racer due to the E10 fuel& I made my own seal. Quote Share this post Link to post Share on other sites
RGD115 0 Posted April 8, 2024 Managed to find a supplier for viton seal but can you tell me what was thickness of one you made Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted April 8, 2024 3mm Quote Share this post Link to post Share on other sites
RGD115 0 Posted April 8, 2024 Many Thanks for your information this means a problem solved Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted April 8, 2024 No problem glad I could help. Quote Share this post Link to post Share on other sites
Captain Scarlet 96 Posted April 17, 2024 Sorry this a bit late,some may know of this company,MC Trading ltd. Amongst other things they do new fuel tanks for Cortina's. Here is photo showing part numbers,I don't know if the seal is available separately. Their phone # is on the photo or look them up on the net. In Sevenoaks I think 1 Quote Share this post Link to post Share on other sites
