sierra3dr 53 Posted August 25, 2023 (edited) ......front subframe mounts,has anyone done it? Edited August 26, 2023 by sierra3dr Quote Share this post Link to post Share on other sites
GhiaMk4/5 207 Posted August 25, 2023 Doing it on a Cobretti kit car with MK4 running gear, I'm not poly bushing as it's lighter than a standard car, so rubber will be sufficient. 1 Quote Share this post Link to post Share on other sites
RichardJ 59 Posted August 26, 2023 I've polybushed the subframe mounts and it seemed to work quite well without much of an increase in noise or vibrations. In general I found the front tolerated polybushing quite well. The back end was a different story entirely. When I polybushed the rear arms it made the car rumbling and growly and you could hear a lot of mechanical noise. Over 50 mph it was uncomfortably loud. 2 Quote Share this post Link to post Share on other sites
sierra3dr 53 Posted August 26, 2023 12 hours ago, GhiaMk4/5 said: Doing it on a Cobretti kit car with MK4 running gear, I'm not poly bushing as it's lighter than a standard car, so rubber will be sufficient. Have you already purchased the rubber mount bushes? Quote Share this post Link to post Share on other sites
GhiaMk4/5 207 Posted August 27, 2023 (edited) Yes, got them off a seller on eGay, the car is way too light for polybushes, hence my preference for rubber. For a Cortina I'd probably polybush it. Edited August 27, 2023 by GhiaMk4/5 Spelling error 1 Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted August 27, 2023 Rubber should be fine on a std front subframe. 2 Quote Share this post Link to post Share on other sites
MK5CortinaEstate 54 Posted August 31, 2023 I've got mine solid mounted, and it isn't much of an issue. Certainly get a lot of feedback through the steering with the way I've got it. 1 Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted August 31, 2023 Ginetta solid mounted the front subframe when they used it. 1 Quote Share this post Link to post Share on other sites
sierra3dr 53 Posted September 2, 2023 Well,they have arrived. Left is for the front,right is for the middle of the inner wheel arch. Although the holes measure the same. Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted September 2, 2023 Std ones are all the same. 1 Quote Share this post Link to post Share on other sites
STEVE440 12 Posted December 10, 2023 Polybushes do come in various grades of hardness, some makes do a grade that is close to the original firmness. People often fit the hard version but these are for race use unless you like your fillings on the floor. The other thing I have found with Poly bushes is they need some miles on them, when new they are often far to hard but once a thousand miles they seem to be a lot better. Quote Share this post Link to post Share on other sites
