AndrewGT 2 Posted November 25, 2023 Hi, just bought a standard airflow GT air filter case. Please can someone let me.know or post picture of how lid should be held on? Is it studs and nuts with spacers or long bolts with spacers? Thanks Quote Share this post Link to post Share on other sites
AndrewGT 2 Posted November 25, 2023 Also, if anyone has a spare filter element lying about, diameter and height please. Quote Share this post Link to post Share on other sites
SusanButcher 33 Posted November 26, 2023 (edited) That''s the early version. After December 1963 the lid was held on with two bolts. But the later one has the same arrangement of two crossbars and four nuts spacers and grommets holding it to the long studs on top of the Weber. Edited November 26, 2023 by SusanButcher Quote Share this post Link to post Share on other sites
AndrewGT 2 Posted November 26, 2023 Thanks. So 2 x bolts presumably with spacers to prevent lid being bent?? Quote Share this post Link to post Share on other sites
SusanButcher 33 Posted November 26, 2023 I guess that's it. It also simplifies the lower part of the cleaner, with the two bolts going into threads cut directly into the metal, and no bracket interrupting the air flow. Quote Share this post Link to post Share on other sites
AndrewGT 2 Posted November 27, 2023 Thanks very much. Quote Share this post Link to post Share on other sites
SusanButcher 33 Posted December 8, 2023 I've measured the size of the filter I use in my GT air cleaner: inside diameter 18cm, outside diameter 23.5cm, height 5cm. This isn't an original Ford filter, it was an altered Mazda unit, but it fits well. Quote Share this post Link to post Share on other sites
consul315 180 Posted December 8, 2023 On 11/26/2023 at 10:26 AM, AndrewGT said: Thanks. So 2 x bolts presumably with spacers to prevent lid being bent?? that´s a genuine MK1 GT bolt: Quote Share this post Link to post Share on other sites
AndrewGT 2 Posted December 9, 2023 Excellent. Just got to find 2 ! Or turn them. Many thanks. Quote Share this post Link to post Share on other sites
AndrewGT 2 Posted December 9, 2023 On 12/8/2023 at 11:27 AM, SusanButcher said: I've measured the size of the filter I use in my GT air cleaner: inside diameter 18cm, outside diameter 23.5cm, height 5cm. This isn't an original Ford filter, it was an altered Mazda unit, but it fits well. Thanks. Think I'm sorted ! Anyone want a chrome K & N type !!? Quote Share this post Link to post Share on other sites
