petespops
Mk5 V6 - l" lowered front springs
2 x -1" front springs
Suit mk5 V6
These are from Rally Design
Pt no RD 1007 -1"
Rated at 275lbs
They were on my Ford 100E believe it or not.
They don't seem to have had a lot of use.
£25  collected from Orpington or £35 posted within UK.
Edited by petespops
Incorrect info
Suit mk5 V6
Pt no RD 1007 -1"
Rated at 225lbs
The Tape Measure has certainly seen some Use !!
Blimey - Must have stiffened up the 100e a bit!
That seems a low rating  std ones are high 200's
Though had were around 300 LB in.
When I took them off, I wondered what they actually fitted, I went on the RD website & V6 Cortina came up.
Yep, just a bit.
You are 100% correct, I read the RD Web page wrong. These are -1" & rated at 275lbs & not 225lbs. I have edited the advert. Thank you for pointing out the mistake.
Lol what you get for being a geek 🤓
