robbierobinson 0 Posted January 2, 2024 Hi does anyone know if XR3i front seats would be suitable for a 2 door GXL would they bolt right in, and is height ok? Has anyone ever fitted? Ideally looking for tombstones? Thanks Robbie Share this post Link to post Share on other sites
sheffieldcortinacentre 772 Posted January 3, 2024 If you fit cortina runners they should be close as the std seats are similar to mk5's. Share this post Link to post Share on other sites
robbierobinson 0 Posted January 3, 2024 Thank you. Robbie Share this post Link to post Share on other sites
J2S 178 Posted January 3, 2024 I put rs turbo seat in Tina 1 Had to cut shut frame and runners to get the fit in properly where as sierra seats bolted straight in with the runners Share this post Link to post Share on other sites
J2S 178 Posted January 3, 2024 (edited) Bolted standard they sit to high legs hitting steering wheel looking through top of windscreen,also the sit to far towards the tunnel making it not centered to steering wheel ,I notched seat to allow the arm to move when rails are flush with base and moved holes over with a plate of set Edited January 3, 2024 by J2S 2 Share this post Link to post Share on other sites
robbierobinson 0 Posted January 3, 2024 They’re nice looking seats, presently have a pair of recaros from a rover (I think) nice seats but do not tilt forward. The seat bouster has gone drivers side, just trying to get ideas for other compatible front seats. Thanks fo the info Share this post Link to post Share on other sites
J2S 178 Posted January 3, 2024 Alfa seats have been used and look good I had cosworth sierra seats in Tina 2 years ago they fitted perfectly for a short . like me Share this post Link to post Share on other sites
robbierobinson 0 Posted January 4, 2024 I’ve seen the posts ref the Alfa seats, understand there’s a bit of work needed to fit, but it’s an option. Ideally after some get tombstones but searched high and low, no luck, keep looking I suppose. Did try Ford recaros years ago, way to high, probably get them to fit with some work. thanks Share this post Link to post Share on other sites
sheffieldcortinacentre 772 Posted January 4, 2024 I have Capri recaro's on the proper cortina recaro mounts in my blue 2dr MK3 . Share this post Link to post Share on other sites
John Mack 342 Posted January 5, 2024 12 hours ago, sheffieldcortinacentre said: I have Capri recaro's on the proper cortina recaro mounts in my blue 2dr MK3 . Not that I've thought too much about it but I'm assuming from your comment above that you couldn't just bolt a Recaro onto a standard 3/4/5 subframe ? Share this post Link to post Share on other sites
sheffieldcortinacentre 772 Posted January 5, 2024 It's two bars that go across as there narrower & two longways to bolt onto original runners as per pic Share this post Link to post Share on other sites
John Mack 342 Posted January 6, 2024 11 hours ago, sheffieldcortinacentre said: It's two bars that go across as there narrower & two longways to bolt onto original runners as per pic Share this post Link to post Share on other sites
robbierobinson 0 Posted January 7, 2024 Thanks will look at capri recaro’s. The Recaro’s I tried years ago did just bolt straight in, but ride height was too high€not sure what they came out of!! Share this post Link to post Share on other sites
sheffieldcortinacentre 772 Posted January 7, 2024 I'll try get some pics tomorrow. Share this post Link to post Share on other sites
robbierobinson 0 Posted January 9, 2024 Thanks that would be good give me an idea on how they look. Share this post Link to post Share on other sites
