echorley 6 Posted February 1, 2024 Hey all, its been loooong time since I've been here! Very happy to be back, although not for a good reason! My Mk3 has had a total re-furb but I've recently noticed that both the fuel gauge and temp gauge have stopped working... now would this easily point to the dial cluster having an issue as they both sit on the same cluster OR could they simply have not been re-connected the last time we had it sent into the garage? (Slight update on reason for garage situation: It had to go in for inspection and somehow the idiot garage it went to managed to screw up the electrics in a phenomenal way so we took it back from them and had to get it into an old timer auto electrician and we think the gauges haven't worked since then.) Thanks in advance! Pics for fun! 1 1 Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 658 Posted February 1, 2024 If their earthing out they'll go to top of the scale. Simple basic check is with ignition on take the wire of the temperature sender & earth it to the engine if the needle goes off the scale the circuit is ok & the sender is faulty, same for fuel tank. But if both have stopped working this points more to the regulator on the rear of clocks being faulty ( it's a silver rectangular box on the back of clocks ). Try a replacement as I'm not sure how you test them. Or it's possible that the plastic circuit board on the rear of clocks has melted especially if something has been connected wrong they can be repaired by soldering a wire across the damaged part. Also make sure the live connection to the clocks is ok ( black wire in the plug) it should have 12v with ignition on. Quote Share this post Link to post Share on other sites
echorley 6 Posted February 1, 2024 17 minutes ago, sheffieldcortinacentre said: If their earthing out they'll go to top of the scale. Simple basic check is with ignition on take the wire of the temperature sender & earth it to the engine if the needle goes off the scale the circuit is ok & the sender is faulty, same for fuel tank. But if both have stopped working this points more to the regulator on the rear of clocks being faulty ( it's a silver rectangular box on the back of clocks ). Try a replacement as I'm not sure how you test them. Or it's possible that the plastic circuit board on the rear of clocks has melted especially if something has been connected wrong they can be repaired by soldering a wire across the damaged part. Also make sure the live connection to the clocks is ok ( black wire in the plug) it should have 12v with ignition on. Awesome, thank you so so so much sheffieldcortinacentre - I'm going to give this a go before the weekend's out, thanks again! Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 658 Posted February 1, 2024 No problem always happy to help if I can. Quote Share this post Link to post Share on other sites
D-FENS 79 Posted February 1, 2024 9 hours ago, echorley said: Hey all, its been loooong time since I've been here! Very happy to be back, although not for a good reason! My Mk3 has had a total re-furb but I've recently noticed that both the fuel gauge and temp gauge have stopped working... now would this easily point to the dial cluster having an issue as they both sit on the same cluster OR could they simply have not been re-connected the last time we had it sent into the garage? (Slight update on reason for garage situation: It had to go in for inspection and somehow the idiot garage it went to managed to screw up the electrics in a phenomenal way so we took it back from them and had to get it into an old timer auto electrician and we think the gauges haven't worked since then.) Thanks in advance! Pics for fun! That's a very smart interior and noticed the left hand drive and foreign number plate . What country are you from ? Quote Share this post Link to post Share on other sites
echorley 6 Posted February 7, 2024 On 2/1/2024 at 10:26 PM, D-FENS said: That's a very smart interior and noticed the left hand drive and foreign number plate . What country are you from ? Thanks D-FENS! We're in Portugal (originally from Plymouth!) 1 Quote Share this post Link to post Share on other sites
