joemayhook 7 Posted April 18, 2024 (edited) Hi I have had fuel seepage over the years from the original and replaced fuel hoses. Guys, what is the best replacement hoses to use? I haven't a swiss bank account but with my kids is the car im happy pay for quality, something I can put on and then forget. Any help guys thanks, ps any rear Mk5 bumpers or Mk5 Bonnets laying around please let me know. cheers x Edited April 18, 2024 by joemayhook Quote Share this post Link to post Share on other sites
John Mack 338 Posted April 19, 2024 18 hours ago, joemayhook said: ..............something I can put on and then forget. Whatever hose you fit it's definitely worth keeping an eye on them. You won't need much as the main run of pipe is plastic/nylon type. I'm guessing a metre length of 8mm(I.D.) hose will be enough? If your carb has a return you'll need more hose though, 6mm ? Definitely worth refreshing the hardwear using proper fuel clips for securing too .......... Mikalor W1 Spring Hose Clips Fuel - Air - Water - Gas - Silicone Hose Clamps | eBay MINI FUEL LINE HOSE CLIP AIR WATER CLAMP MIKALOR | eBay If you run the car on normal E10 unleaded then the hose you buy needs* to be resistant to ethanol, if you search the forum then there'll be info on what markings/specification to look out for. * or replace standard hose every couple of years, which isn't that bad an idea. Quote Share this post Link to post Share on other sites
joemayhook 7 Posted April 19, 2024 That's so helpful John, a nice job for next weekend. cheers Quote Share this post Link to post Share on other sites
mk4savage 62 Posted April 21, 2024 I replaced mine with Cohline fuel pipe as it was recommended on here. Got off eBay. Quote Share this post Link to post Share on other sites
