norton
transplant
They'll fit sierra MK3 Granada, MK3 transit.
No idea seen all sorts of letters on them. Probably some internal code at engine plant.
that's how i'll advertise the bits then , with "and other PINTOs" added.  I have no need for the carb or alternator and i'm not sure i can use the flywheel/clutch, although people have told me I could, so I'll sell all them off if I can, and keep just the block and cylinder head intact against future need.
initial look at the engine and the carb is a Weber so i might be able to use it , i don't know what spec it is as yet, maybe someone can tell.
 EDIT i think it may be a 28/30 dfth. would there be any advantage using this on my Cortina ?  currently has a new 34ICH on it..carb2.jpg
Edited just now by norton
Edited by norton
You can't use the flywheel & clutch it's a 2.0 so bigger 215mm x 23 spline as opposed to  190mm x19 spline.
You can use the carb if you alter the cable/linkage & the air filter won't fit it's too big.
Trust me I've been doing this stuff circa 40years!
that's why I'm asking. I don't need any of the bits, so I'm planning on selling them if I can. Just keeping the block and cylinder head.
sold
advertised now, i can bring to S Yat if anyone wants it https://www.adverts.ie/parts-accessories/weber-carb-ford-sierra-granada-other-pinto/33890711?notification=58b600863d23d9235be8a5add5846b13-1716231996
The alternator i'm keeping as it's a standard Bosch unit, straight swop on to the Cortina.
Edited by norton
