Stuwindsurf 4 Posted May 29, 2024 This has probably been discussed many times before so apologies in advance. I want to fit power steering to my Mk3 cortina. I don't necessarily need something that will bolt in with minimal changes (although that would be nice). I did read somewhere that a Cortina mk4/5 power steering rack would work but I haven't been able to find one of those so far. So looking for available rack options the right length, happy to make mounts, hydraulic pipes etc. I've come across a sierra 4wd psr, does anyone know if that would have potential? I'm not sure what the difference is between the sierra 2wd and 4wd rack? I hoping to hook whatever rack I end up with to the standard Range rover pump on the 3.5 V8 that's going in. Would that be a problem or does both the pump and rack have to match, ie from the same car? Thanks in advance for any help/info. Stu Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted May 29, 2024 The 4wd is slightly different to 2wd mounts etc due to the weird cross member they have.. mating pump is only size/thread of fittings ( any hydraulic place shouldn't have a problem) I think some use the same pump as ford Audi & pug did at one point. Quote Share this post Link to post Share on other sites
Stuwindsurf 4 Posted May 29, 2024 Thanks, do you know if the Sierra racks are the correct width for the Cortina? although I guess I could machine down the tie rod ends if they're too long Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted May 29, 2024 Overall width yes, the track rod ends are same thread so cortina ones fit.. Quote Share this post Link to post Share on other sites
Stuwindsurf 4 Posted May 30, 2024 8 hours ago, sheffieldcortinacentre said: Overall width yes, the track rod ends are same thread so cortina ones fit.. Thanks, that's really helpful Quote Share this post Link to post Share on other sites
sierra3dr 53 Posted June 3, 2024 The 4WD Sierra rack mounting is on the front of the subframe as that of a Cortina. The Pinto PAS used the saginaw pump. You have aggro in finding the twin pulleys for the crank,water pump and alternator. Might be worth look into the EPS method. Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted June 3, 2024 The ohv Pas will work fine with single belt. He's running a rover v8 1 Quote Share this post Link to post Share on other sites
sierra3dr 53 Posted June 4, 2024 On 5/29/2024 at 7:18 AM, Stuwindsurf said: the 3.5 V8 that's going in. Oh I yeah I can never see the wood for the trees Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted June 4, 2024 Who said that , damn trees Quote Share this post Link to post Share on other sites
disco_monkey79 33 Posted April 6 Does anywhere still sell cortina inner tie rods? And if so, where? Internet is failing me. I have been refitting the front suspension and steering. Whilst the sierra rack looked the right length off the car, both wheels are now toe out, so the sierra rods are too long I just measured the cortina arms that came off the car and they are 30mm shorter, so would certainly help. Thanks Quote Share this post Link to post Share on other sites
disco_monkey79 33 Posted April 6 P.s. The old ones are knackered, otherwise I would just use them Quote Share this post Link to post Share on other sites
Beeper 85 Posted April 6 I'm just curious as to why you/anybody would 'need' PAS on a Cortina with a Rover V8, when the Pinto SOHC block is heavier than the Rover V8 block? I suppose wanting and needing are two different things though. Quote Share this post Link to post Share on other sites
John Mack 341 Posted April 6 I'd like PS please ! Quote Share this post Link to post Share on other sites
markymarkthree 178 Posted April 6 (edited) 1 hour ago, Beeper said: I'm just curious as to why you/anybody would 'need' PAS on a Cortina with a Rover V8, when the Pinto SOHC block is heavier than the Rover V8 block? I suppose wanting and needing are two different things though. You sure about that ? Interweb says ohc 140 -160 kg fully dressed v8 170 - 180 kg fully dressed. Edited April 6 by markymarkthree Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted April 6 The inners are same as MK2 escort std models ( RS are imperial thread same as all mk1s)with metric thread. 1 Quote Share this post Link to post Share on other sites
