Cortina1975
Mk3 1600 Speedometer - inaccurate
Hi all,
Is there anywhere that repairs Cortina speedometers - mine is reading 12 MPH at 30 MPH. Even considering I probably have the wrong drive gear fitted on the 5 speed box this seems way out.
Or is it possible to calibrate them somehow?. The odometer was seized but managed to get that going with some wd-40.
Thanks in anticipation of any replies.
Cheaper to get another £15 Inc p&p.
It's probably misreading that much due to seizure , the type 9 in a 1.6 usually to far out (unfortunately you can't get one to match the 1.6 cortina diff).
Let me have a pick of which Speedo you have, should be one with tripmeter being an XL.
On 4/2/2024 at 9:48 PM, Tigdlo said:
No, you’d need fewer teeth to drive the speedo faster
Thanks Dr Craig. Indeed has a trip meter..would be great if you have one :cheers:
