wolfrace 116 Posted September 18 Hi folks, For sale my 2 door mk3. Essex V6, 5spd Genuine Savage bonnet (rarest part I can think of on a mk3) It’s a 3.0 Essex v6 that I believe was bored out to 3.1 according to the Classic Ford magazine feature done on the car a number of years ago, I don’t have any paperwork to support that though. It will need tuning and trailering away. Work required as far as I know. Since fitting a brand new 38 carb it needs tuning, probably floats adjusting and fuelling setting up. It might require a new ‘W’ spacer plate under the carb, it just has a generic one currently. Sort the ignition timing, maybe reroute a couple of the fuel hoses (I’ve run all the hard lines using kunifer and used quality gates barricade hoses) want the cooling system bleeding. The windscreen washer jets need plumbing up and the interior light switches for the door jambs need sourcing and fitting. Then you’ll want to MOT it. Obviously it’s MOT exempt and that’s your choice but it was my plan to put one on it anyway. There may be other things, there always is with old cars. With all that in mind you will need to trailer it away. I can send you a vid of me driving the car to at least show it runs. It might seem straight forward stuff, & it is if you have some spare time - I don’t, having a young family and massive house renovations taking up all my time. It’s parked in the garage at my folks house & I rarely (like 2 or 3 times in the last year) get over for a few hours to work on it. Heres a list of parts fitted/work done; Mechanical / Suspension: Steel timing gear Lumenition electronic ignition New genuine Weber 38 carburettor (£300) Stainless steel side exit exhausts (both sides) New front and rear crank oil seals (burton power) New spigot bearing New gaskets; sump, inlet, fuel pump, front timing cover, carb, rear oil seal carrier, rocker gasket (from burton power) New H/T fixings including new studs for: exhaust manifolds, carb, oil pump and thermostat housing. New upper and lower front ball joints o/s and n/s New trackrod ends New steering rack gaiters New floflex Polybushed front subframe New floflex Polybushed subframe to chassis mounts New steering column bearing New front brake flexis New GAZ adjustable front dampeners Upgraded 18mm front ARB New starter motor (rare version for this engine & gearbox combo) at a cost of £260 New remote starter motor solenoid I’ve replaced all but one of the fuel hoses with Gates Barricade New Kunifer fuel lines. Electrically: New old stock interior wiring loom Reconditioned headlamp backing plates and chrome trim rings, all adjusters work. New domed glass headlights New upgraded ceramic headlight H4 sockets New old stock indicator units New TIM voltage, oil temperature gauges. Tim oil pressure gauge New ISO radio harness LED cluster fitted into rear numberplate housing. Interior: GT/GXL Centre console GT Tombstone seats re-trimmed in genuine leather (and rear seat and door cards) New 3 piece carpet New carpet underlay New bitumen/aluminium floor sound insulation pads New old stock Rear seatbelts installed All vent pipes and the air distribution unit were removed and cleaned out when dash was out then refitted and joints sealed with duct tape. Floor painted before bitumen pads installed. Wheels & tyres: Steel 13” minilight style, freshly shot blasted and powdercoated. 185/70/13 rear 175/70/13 front Bodywork: Various sections repaired with new panels & solidly welded repairs sections. PU seam-sealed, painted with a quality zinc primer then top coated before being undersealed where required. Chassis rails, box sections, front & rear inner valances and inside doors, rear quarters etc were spray filled with pre-heated cavity wax after welding was undertaken. All the usual rot areas on cortinas (sills, front floor pans, subframe chassis mounts, rear valance, inner wing top rails, have been addressed or were stripped back and checked) Savage bonnet Bonnet pins Price £13500 or offers. I am willing to negotiate & open to offers, I can remove the bonnet for a decent discount and supply it with a steel (vented) one. Just try me, I’m not going to get all upset if you can’t offer what I want so don't be shy. However I’m not interested in a swap / part ex (never seems to stop people asking though eh…) location: Oswestry If there’s anything you want to know, give me a shout. I don’t get on BSC frequently thesedays but will be checking PM’s periodically so please bear with me. Quote Share this post Link to post Share on other sites
