m0osx 0 Posted September 28 Hi folks, can anyone tell me where the vacuum pipe from the a servo connects to the inlet manifold please? i know the servo will not improve the brake performance, but im getting old and i would like a softer brake pedal. There is a flat head grub screw on the inlet manifold, is this where the vacuum pipe goes? Thanks, Andy. Quote Share this post Link to post Share on other sites
mk2sav 38 Posted September 28 A nos Fomoco inlet manifold for a Ford MK1 Cortina | eBay Do you have this type of manifold Andy ? The cars with a webercarb pretty much all have a take off but that type in the advert only appears to have that threaded take off and if thats all there is , I would think that it would be usable if you can find an adaptor . Quote Share this post Link to post Share on other sites
m0osx 0 Posted September 28 Hi mk2sav, thanks for that, yes that's the type of manifold that I have, the flat head grub screw that's on my one probably has never been removed since it was fitted. I guess I should use some heat to try and remove it. Pity we don't know which thread it is, but I'm sure something will fit it. Should be ok I guess and like you said, that's probably the only option. Quote Share this post Link to post Share on other sites
mk2sav 38 Posted September 29 Just been reading on forums and it seems most tend to drill and tap a thread into the manifold if you have the tools available ?? Steve. Quote Share this post Link to post Share on other sites
Lotuscops 77 Posted September 29 Depending on which type of carb/manifold you have there are block gaskets that sit between the two with a brass pipe coming off them, or you could make one easy enough. Quote Share this post Link to post Share on other sites
m0osx 0 Posted September 29 Thanks steve, I will probably go down that route as it's going to be impossible to get the grub screw out. I was look ING for examples online of the method you described, but I can't find anything. Quote Share this post Link to post Share on other sites
m0osx 0 Posted September 29 Thanks Lotuscops, this is the manifold I have, i made an adaptor plate and fitted an autolite carburetor from a mk2 Escort, a few years ago. It was a brand new carburetor, (nos) I guess I'm better off going the drilling/tapping route Which size of drilling hole/tap would you recommend I use? s Quote Share this post Link to post Share on other sites
