Lobby 105 Posted October 2, 2024 Hi all, I'm looking to source a new Weber 32/36 DGAV for my Pinto, is there a difference between part numbers WEB22680.872 and WEB22680.873? Can anyone recommend a good supplier once I know which model I need? Many thanks. Quote Share this post Link to post Share on other sites
J2S 164 Posted October 3, 2024 Ones auto choke the others manual Maybe ? Quote Share this post Link to post Share on other sites
John Mack 338 Posted October 4, 2024 On 10/2/2024 at 10:07 PM, Lobby said: ......is there a difference between part numbers WEB22680.872 and WEB22680.873? I would say no? I put the numbers into ebay, only difference I can see is that one comes with a fitting kit.....I noticed that both have the return outlet blanked? 873 is advertised as suitable for x-flow too ? Craig/Sheffield cortina centre will have info on jet sizes etc....wonder if they correspond to the ebay adverts ?? 872.... New GENUINE Weber 32/36 DGAV carb. carburettor Ford Pinto OHC autochoke Webber | eBay 873... GENUINE Weber 32/36 DGAV carb. carburettor Ford Pinto Xflow 1.6/2.0 auto choke | eBay BTW what's wrong with the carb you have? Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 759 Posted October 4, 2024 At a guess I'd say it's basically as stated above. Jets are listed as different (wether 1.6 or 2.0) but thousands of them were retro fitted without any noticeable differences. My 1.6 crayford has a 2.0 one that's been on it for years. Problems only really occur if you fit a 38DGAS from a 3.0 V6 as it's to big without rejetting & pointless on a 1.6. Quote Share this post Link to post Share on other sites
Lobby 105 Posted October 4, 2024 3 hours ago, John Mack said: I would say no? I put the numbers into ebay, only difference I can see is that one comes with a fitting kit.....I noticed that both have the return outlet blanked? 873 is advertised as suitable for x-flow too ? Craig/Sheffield cortina centre will have info on jet sizes etc....wonder if they correspond to the ebay adverts ?? 872.... New GENUINE Weber 32/36 DGAV carb. carburettor Ford Pinto OHC autochoke Webber | eBay 873... GENUINE Weber 32/36 DGAV carb. carburettor Ford Pinto Xflow 1.6/2.0 auto choke | eBay BTW what's wrong with the carb you have? Hi, Thanks for the info, my carb is pretty worn out, even after a rebuild it hesitates and has flat spots. It's also weeping fuel around the bolt head which is underneath and between the fuel inlet and blocked off return. I'd also like version with the threaded in inlet, rather than the press fit version. 1 1 Quote Share this post Link to post Share on other sites
