Stuwindsurf 0 Posted November 3, 2024 I think I can remeber reading somewhere that the mk3 Cortina front wheels sit out slightly wider than the rears, can anyone back that up? Also if that's true does anyone know what that difference is?... Thanks Stu Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 658 Posted November 3, 2024 Its a few mm I think would have to check. Quote Share this post Link to post Share on other sites
Stuwindsurf 0 Posted November 4, 2024 7 hours ago, sheffieldcortinacentre said: Its a few mm I think would have to check. Thanks Craig, if you get a chance it would be appreciated Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 658 Posted November 4, 2024 Seems front & rear track is listed as 56 inches ( wheel centre to centre). Quote Share this post Link to post Share on other sites
Stuwindsurf 0 Posted November 5, 2024 10 hours ago, sheffieldcortinacentre said: Seems front & rear track is listed as 56 inches ( wheel centre to centre). Oh ok thanks, so both the same then? Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 658 Posted November 5, 2024 Yep , I thought they were slightly different must be Capri or one of the others. Quote Share this post Link to post Share on other sites
Captain Scarlet 95 Posted November 7, 2024 Body is slightly wider at the rear i think, makes it look like a wider track,or different wheel offset. Quote Share this post Link to post Share on other sites
Tigdlo 27 Posted November 7, 2024 Up to around 25 years ago, most cars had a wider front track than the rear. There were a few exceptions, I believe the Escort mk1 and 2 were so. Quote Share this post Link to post Share on other sites
Stuwindsurf 0 Posted November 13, 2024 On 11/7/2024 at 10:55 AM, Captain Scarlet said: Body is slightly wider at the rear i think, makes it look like a wider track,or different wheel offset. I got the front suspension mounted and measured up today and yes your right, the wheel arches on the back are slightly wider than the fronts which is why the front wheels look like they stick out further Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 658 Posted November 13, 2024 Optical dilusion! Quote Share this post Link to post Share on other sites
Captain Scarlet 95 Posted November 29, 2024 On 11/13/2024 at 8:38 PM, Stuwindsurf said: I got the front suspension mounted and measured up today and yes your right, the wheel arches on the back are slightly wider than the fronts which is why the front wheels look like they stick out further Easy to check,plumb bob from the arch to the floor ,mark the floor roll. The car out of the way and measure. Mine measures 1675mm wide at the front,and 1695mm wide at the rear. Some front wings may vary a small amount, but the rear of the body less likely,unless there has been accident damage,or poor quality repair to the rear arches. sales brochure gives one width of 67.1” (1704.34) which would include the bumpers . Quote Share this post Link to post Share on other sites
