sierra3dr 53 Posted November 17, 2024 I don't know if I am having a blonde moment,my MK5 has stopped delivering fuel.I do have an inline filter so I can see if it fills,which it does not anymore. I have put on a new pump,no change. I have pulled out the pump pushrod and the length is about 44mm,which as we know,is for the 1.6 and the 50mm is for the 2 litre engines. And on mine there is no spacer. So,if the 2 litres had the spacers on,if they are 5mm thick,meaning the pump is 5mm further away from the rod Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted November 18, 2024 Yes but I always thought the both use the spacer. Beaware that the cvh & cologne V6 pump looks identical & fit not sure it length varies ooh matron 2 1 Quote Share this post Link to post Share on other sites
sierra3dr 53 Posted November 19, 2024 I'm just thinking that quite possibly that the fuel sender might be corroded....Were all Cortinas fitted with transparent plastic tube on the fuel line? Quote Share this post Link to post Share on other sites
John Mack 341 Posted November 19, 2024 27 minutes ago, sierra3dr said: Were all Cortinas fitted with transparent plastic tube on the fuel line? As far as I know, none of them have transparent lines? 2 Quote Share this post Link to post Share on other sites
sierra3dr 53 Posted November 19, 2024 6 hours ago, John Mack said: As far as I know, none of them have transparent lines? hmmm..interesting,mine has. I'll have to replace it with copper Quote Share this post Link to post Share on other sites
Tigdlo 27 Posted November 19, 2024 On 11/17/2024 at 7:26 PM, sierra3dr said: I don't know if I am having a blonde moment,my MK5 has stopped delivering fuel.I do have an inline filter so I can see if it fills,which it does not anymore. I have put on a new pump,no change. I have pulled out the pump pushrod and the length is about 44mm,which as we know,is for the 1.6 and the 50mm is for the 2 litre engines. And on mine there is no spacer. So,if the 2 litres had the spacers on,if they are 5mm thick,meaning the pump is 5mm further away from the rod That’s a new one on me. I thought that the pump and pushrod were the same on all Pintos……….. Quote Share this post Link to post Share on other sites
John Mack 341 Posted November 19, 2024 6 hours ago, sierra3dr said: hmmm..interesting,mine has. I'll have to replace it with copper They're plastic/nylon but not transparent, can you take a picture of what's on the car? 1 Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted November 19, 2024 Fuel line was always black plastic with a short piece of black rubber at the join. 1 Quote Share this post Link to post Share on other sites
sierra3dr 53 Posted November 20, 2024 5 hours ago, John Mack said: They're plastic/nylon but not transparent, can you take a picture of what's on the car? Will do 👍 Quote Share this post Link to post Share on other sites
martog 149 Posted November 21, 2024 That clear plastic tube with the nylon weave in it is rubbish. It's a quick fix, but needs to be sorted with proper rubber fuel hose interconnector's between the metal and black plastic lines that run beneath the car. 1 Quote Share this post Link to post Share on other sites
sierra3dr 53 Posted November 21, 2024 57 minutes ago, martog said: That clear plastic tube with the nylon weave in it is rubbish. It's a quick fix, but needs to be sorted with proper rubber fuel hose interconnector's between the metal and black plastic lines that run beneath the car. What was his phrase used in the Police drama Hunter? Quote Share this post Link to post Share on other sites
sierra3dr 53 Posted November 21, 2024 On 11/19/2024 at 6:54 PM, John Mack said: They're plastic/nylon but not transparent, can you take a picture of what's on the car? here you go Mr Mack Quote Share this post Link to post Share on other sites
John Mack 341 Posted November 21, 2024 5 hours ago, sierra3dr said: here you go Mr Mack Not sure what to make of that ? I'd be for trying to get it further off the ground though! Agree with the above ref the garden hose type stuff with the nylon weave through it. 1 Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted November 21, 2024 6 hours ago, sierra3dr said: What was his phrase used in the Police drama Hunter? Don't eat yellow snow? 1 Quote Share this post Link to post Share on other sites
sierra3dr 53 Posted November 21, 2024 4 hours ago, sheffieldcortinacentre said: Don't eat yellow snow? don't remember that one.......his phrase was "it works for me" Quote Share this post Link to post Share on other sites
