t.onyb 31 Posted January 12, 2025 (edited) Borg Warner - South Africa Ford This Rear Axel and propshaft was from a 1975 - South African Ford Cortina MK3 It was a 3.0 Litre XLE - 4 door saloon. One of the shafts has a buckle and makes a whining noise. Gave the car a slight wobble when traveling. I did try to repair this but failed miserably. So ended up replacing for a recon Atlas. I am no mechanic and the garages I went to also proved to be as useless. Especially JD Classics in Chelmsford, Essex. All I know is this:- The shaft has 23 teeth which run 50mm along shaft The shaft has a total length of 740 mm with a 25.4 diameter I’ve been told the diff has a ratio of 3.1 :1 But equally told the ratio could also be 3.44:1 or 3.45:1 Sorry I haven’t a clue which is correct - so please don’t take this information as gospel, a guide at best Open to offers Happy to answer questions and send more pictures if needed - anything more I can’t help!! Collection only from Barking - East London Easy access from M25, M11, A406, A13 Edited January 14, 2025 by t.onyb Quote Share this post Link to post Share on other sites
John Mack 337 Posted January 12, 2025 An indication of price might help interested parties, I'm sure someone will be interested. If you don't mind me asking, how much was the reconditioned Atlas......was it bought from an axle specialist/private seller or did you buy it and then have it overhauled ? (PM if you'd rather not broadcast the cost involved ?) GLWS Quote Share this post Link to post Share on other sites
