TIB3300 455 Posted April 11 8 hours ago, Stuwindsurf said: Did you finish getting this up and running?... Stu Morning Stu, Yeh works great I will update the thread 1 Quote Share this post Link to post Share on other sites
Stuwindsurf 4 Posted April 11 49 minutes ago, TIB3300 said: Morning Stu, Yeh works great I will update the thread Great! Look forward to it as I am considering going this route Quote Share this post Link to post Share on other sites
TIB3300 455 Posted April 18 (edited) Here's what I have, as I said I wanted people to be able to do it at home. So after I had to use a lathe I stopped documenting the build sorry. Here is the converted pedal box and an original Cutting off the motor Cutting the original inner shaft Edited April 18 by TIB3300 Quote Share this post Link to post Share on other sites
TIB3300 455 Posted April 18 (edited) mounting points Use mounting point B for the main supports , mounting points A and just to hold the head stock Edited April 18 by TIB3300 Quote Share this post Link to post Share on other sites
Stuwindsurf 4 Posted April 18 Thanks for the updated pics! Nice job! It seems to sit tucked out of the way nicely. I was concerned it would hang down below the dash and look ugly. I have a lathe and a mill so the machine work shouldn't be a problem. So ref wiring it in, could you tell me what was involved? Many thanks Stu Quote Share this post Link to post Share on other sites
TIB3300 455 Posted April 18 42 minutes ago, Stuwindsurf said: Thanks for the updated pics! Nice job! It seems to sit tucked out of the way nicely. I was concerned it would hang down below the dash and look ugly. I have a lathe and a mill so the machine work shouldn't be a problem. So ref wiring it in, could you tell me what was involved? Many thanks Stu Hiya Stu The wiring is easy As far as I know, there are 3 different control types 1 with a little controlled potentiometer 2 one that used GPS 3 This one that uses the force applied to the wheeled potentiometer inside Automatic - Corsa B C - Electric power steering controller Kit - EPAS Kit - OPEL | eBay UK Quote Share this post Link to post Share on other sites
TIB3300 455 Posted April 18 One of the thing I had to bodge, was this, as I couldn't find a splined coupler for the bottom on the corsa PAS unit. This is the top part of the UJ that come with the Corsa unit Quote Share this post Link to post Share on other sites
TIB3300 455 Posted April 18 If you do decide to do it, feel free to use this post to ask questions and I can guide you through it Quote Share this post Link to post Share on other sites
TIB3300 455 Posted April 18 (edited) I cant remember why I cut this so short? This is something that may not needed to be done Edited April 18 by TIB3300 Quote Share this post Link to post Share on other sites
Stuwindsurf 4 Posted April 19 That's great, thank you for the info 👍🏻 Quote Share this post Link to post Share on other sites
