ShortyPaul
4 speed gearbox
Hi, what gearbox was in the mk4/5 cortina 2.0?
Will a type 3 fit also were 1.6 different from 2.0 and was the ohv gearbox same as ohc?
Basically I'm struggling with my type 9 and
thinking of going back to 4 speed but not sure which will fit.
You need a 2.0 4 speed then as 1.3/1.6 is different ( same in ohc/ohv) smaller clutch & prop than the 2.0.
What problems? as 2.0 to 5 speed is easiest of the lot.
What's up with your type 9 that makes you want to change back?
Please sign in to comment
Sign In Now
