sierra3dr
snapped....
...clutch cable,,,,bugger!!.....Which year did the Cortina start having the ratchet and pawl self adjusting clutch? I know on my 1979,it came with the ratchet and pawl,but got rid of it,and now using the manual adjustment cable since 2020...I don't see many manual adjusting cables
As far as I know all mk5's would've left the factory with a self adjusting cable.  Like you I fitted a mk3/4 pedal and cable.
Here's one ........ Ford Cortina MK3 MK4 Pinto 1.6 2.0 SOHC Clutch Cable. cps1010 for sale at classic parts shack
:thumbsup:
As above all mk5's, make sure you get the plastic horse shoe & pin with mk3-4 pedal.
:thumbsup:
thanks
I a similar/same (?) set up on my Mk1 Fiestas. Jeez what a crap idea! I got stranded outside Oulton Park one afternoon when a tooth stripped and jammed with the clutch half way in, so no drive. I had to call my friend for a tow, unfortunately he was in Vegas on a business trip, so I had to call his Dad to come and get me!
totally agree,,,crap idea....did all the MK1 Fiestas have them?  A shame you cannot convert to manual adjustment
Kits were available in period
In reply to Sierra3dr, yes I think they all had it. I don't have a Mk1 Fiesta anymore, but had two in the past. I had to buy adjusters for both, about £7 from Ford, (IIRC, or was it £27? It was a long time ago) Great little cars until you meet a Mk2 Fiesta coming out of a side road as you overtake a dozy Datsun driver and,.....BOOM! Now I have no idea what my current clutch setup is like. It's a Peugeot, with the dreaded 3 cylinder 1.2 wet belt engine (run awayyyy run awayyyyy!). Lots of electronics, no CD player, No sat Nav unless you have an Apple phone to connect. Irritating warnings on the dashboard display, door open, release handbrake, tyre pressure (corner specific) below recommended limits, service due in so many miles or 4 weeks! After this car I'm going back to a Toyota! Mind you, robbing Rachel Thieves hasn't got me with the road tax, it's still only £35.
Edited by Beeper
  • Sad 1
Clutch will probably be hydraulic with one of those slave cylinders inside bellhousing so it's a full strip down & might as well swap clutch & flywheel mate while it's apart so another few hundred on bill ( they call it progress 🤣🤣)
