V6Bakkie
V6 Clutch Fork Rubber
Hi - I have a 1985 V6 Bakkie with a 4 speed Type 5 box - I need a clutch cover rubber boot but they do not seem to be readily available - has anyone come across a source or can another type be adapted?
Thanks
Not sure if its the same as the early external linkage box as fitted to Capris or not - basically the same as a Mk3 Cortina one only larger !! I sold one of these on ebay recently and hesitate t say how much if went for and it wasn't only one or two bidders so you will struggle to find one I think (if it is the same !)
It should be the std one used across the std 70's  ford  range of rwd boxes , MK3/4/5,Granada mk1-2, Capri all, sierra type 9's, escort mk1-2. With cable clutch.
Not to argue with Craig but at least some of the 3 litre Capri ones were larger than the standard one . The one I had was marked 70EB for Capri .
Think the earlier one (pre 72ish) was different .
