C0RKTINA 108 Posted August 11, 2025 about aa week ago i found i had a leak at the rear of the engine...i found the rocker cover gasket wasnt sat right, so I fitted another. Several days after, im finding three spots of oil appearing on the floor in a line roughly at the back of the engine.... is it possible the oil is running off the engine or gearbox still or should i look for another leak? there was quite alot of it, but now there's a lot less oil dripping now, just three fairly small spot....i cleared them away earlier , but they're back even though i didnt run the engine. Pretty sure it's engine oil by the way.....i suppose the crankshaft oilseal might be a suspect..... the oil was acculumating in no4 plughole, so im pretty sure the gasket was the culprit.....but i could have another leak i guess....would it take that long for oil to run off the engine? Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted August 11, 2025 If you didn't clean engine I'd say it's probably remains of leak. Quote Share this post Link to post Share on other sites
C0RKTINA 108 Posted August 11, 2025 25 minutes ago, sheffieldcortinacentre said: If you didn't clean engine I'd say it's probably remains of leak. good good....no, i was planning to get the pressure washer out, but didnt yet. Quote Share this post Link to post Share on other sites
