V6Bakkie 1 Posted December 26, 2025 I have an early type 9 gearbox with V6 Essex bellhousing which is supposed to have come out of an SA Bakkie to convert my current 4 speed to 5 speed – however I have my doubts - The initial make or break issue for me is the relative height of the input shaft to the bellhousing/engine mounting flange – on my 4 speed it protrudes about 3mm - on the 5 speed it is about 10mm low. So my initial question is – will the shaft have enough (if any) purchase into the crank spigot bearing? Quote Share this post Link to post Share on other sites
markymarkthree 178 Posted December 26, 2025 2 hours ago, V6Bakkie said: I have an early type 9 gearbox with V6 Essex bellhousing which is supposed to have come out of an SA Bakkie to convert my current 4 speed to 5 speed – however I have my doubts - The initial make or break issue for me is the relative height of the input shaft to the bellhousing/engine mounting flange – on my 4 speed it protrudes about 3mm - on the 5 speed it is about 10mm low. So my initial question is – will the shaft have enough (if any) purchase into the crank spigot bearing? Sounds like you have a Pinto type 9, with the shorter input shaft than the V6 type 9. Can you put a picture up ? Quote Share this post Link to post Share on other sites
V6Bakkie 1 Posted December 26, 2025 The input shaft is also 18 teeth and first gear 29 teeth Quote Share this post Link to post Share on other sites
markymarkthree 178 Posted December 26, 2025 That looks like a Pinto box. Length of protruding shaft from sleeve needs to be about 85 ish mm. Yours looks about 70mm. Also the v6 type 9 is a stronger box. Quote Share this post Link to post Share on other sites
markymarkthree 178 Posted December 26, 2025 Hopefully you have the correct bellhousing, as it needs to be from a 2.5 Essex. Quote Share this post Link to post Share on other sites
V6Bakkie 1 Posted December 26, 2025 Thanks for the quick replies Mark - you are correct it's 70mm For me it doesn't look worth persevering as the gear ratios are not correct for a V6 even after overcoming the shaft length :-( The bellhousing is an oddity - although for an Essex it is for a hydraulic clutch (side mounted flanged slave) with the pivot point on the "wrong" side and a poorly welded blanking plate to convert to early layshaft - whilst not insurmountable to overcome/change to cable - I think I am going to stick with the 4 speed - an expensive lesson learned :-( Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 764 Posted December 26, 2025 That's probably from a P type Taunus as over there they had Essex V6 with a hydraulic clutch ( they were a real bitza) bakkies always had a cable, as said you need a V6 box ( beware when buying one especially if it has no bell housing as diesel boxes also have the longer input shaft & a lower 1st gear) it's a minefield with type9 5 speeds especially V6 ones. Quote Share this post Link to post Share on other sites
