chris mk3
Rev counter wiring up, how?
Posted (edited)
Can anyone help?
I'm a dummy when it comes to the sparks, here is what I've got to work with, going into Cortina rev counter clocks
Edited by chris mk3
It takes it's pick up from the negative side of the coil, at the clocks it may be possible to figure it out following the "trace" on the circuit board........judging by pic I'm thinking this is on MK3 facelift or MK4/5 ?
Posted (edited)
Yes mate MK3 Facelift , I've added lights on the board, so I know the two inner connections must be for the rev counter, that's all I know
Edited by chris mk3
I take it you're adding a rev counter dash to a car that previously just had speedo/temp/fuel gauges ?  I remember doing this to my Crusader about 20 years ago , comparing the rear of the 2 dash clock sets will help, the wire colours are possibly NOT in the same positions on the multi-plug.
Hopefully Craig will have the definitive answer  !?
Yes mate exactly, Craig has given me a bit of guidance, but not exactly sure where to move the plugs on the connector
Damn I forgot about this, I blame old age.
Posted (edited)
Facelift onwards dash plugs with rev counter, plugs have a small number from 1-5 on small plug ,1-8 on large plug the order of wires is as follows
Small plug
1- empty,
2 - brown X2
3- green
4- black/yellow X2
5- grey/yellow ( sometimes grey/red)
Large plug
1- black/white
2- blue/black
3- brown ( links to brown on small plug)
4- blue/green
5- black/yellow
6- blue
7- blue/white
8- red/white
🤣no worries Craig lad, but thanks for this I've still two days off, will get stuck in on this 👍
Can't find the plugs at moment.
Thanks Craig lad 😀, you never let us down 👍👍👍
I must admit, I prefer the older white dials.
Good to hear you're sorted :biggrin:
Great glad I could help.
