Stuwindsurf 4 Posted March 11 Hi, Does anyone else have issues with legroom under the steering wheel? I have a 14" Mountney steering wheel fitted to my facelift Mk3 and the only way my legs will fit under the steering wheel comfortably to operate the pedals is to let me knees fall out either side of the steering wheel which feels really odd! Is this a common thing with the Mk3's?... Quote Share this post Link to post Share on other sites
markymarkthree 178 Posted March 11 3 hours ago, Stuwindsurf said: Hi, Does anyone else have issues with legroom under the steering wheel? I have a 14" Mountney steering wheel fitted to my facelift Mk3 and the only way my legs will fit under the steering wheel comfortably to operate the pedals is to let me knees fall out either side of the steering wheel which feels really odd! Is this a common thing with the Mk3's?... Speaking as someone who is 6' 2". Never had a problem and the std wheel is bigger 15.5" wide 14.5" tall. Quote Share this post Link to post Share on other sites
Stuwindsurf 4 Posted March 11 Thanks Mark, then there must be something different about my set up 🤔 Would you mind measuring the distance between the bottom of your steering wheel and the seat if you get a minute, it would be much appreciated Quote Share this post Link to post Share on other sites
markymarkthree 178 Posted March 11 1 hour ago, Stuwindsurf said: Thanks Mark, then there must be something different about my set up 🤔 Would you mind measuring the distance between the bottom of your steering wheel and the seat if you get a minute, it would be much appreciated 7 inches. Quote Share this post Link to post Share on other sites
Stuwindsurf 4 Posted March 11 34 minutes ago, markymarkthree said: 7 inches. Thank you 😊 Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 765 Posted March 11 1 hour ago, markymarkthree said: 7 inches. Bragger 1 3 Quote Share this post Link to post Share on other sites
disco_monkey79 33 Posted March 12 On 3/11/2026 at 12:28 PM, Stuwindsurf said: Hi, Does anyone else have issues with legroom under the steering wheel? I have a 14" Mountney steering wheel fitted to my facelift Mk3 and the only way my legs will fit under the steering wheel comfortably to operate the pedals is to let me knees fall out either side of the steering wheel which feels really odd! Is this a common thing with the Mk3's?... Is it to do witht he aftermarket wheel boss? Ie has it moved the wheel forwards or back, relative to where the standard wheel would sit? Sounds like you may be on to this, but thought I would chime in anyway. I am 6' 7", so will be moving the seat further back, as well as changing the wheel. Stoopid legs. Quote Share this post Link to post Share on other sites
dgo 80 Posted March 12 A photo might be useful 😄 Quote Share this post Link to post Share on other sites
Stuwindsurf 4 Posted March 13 16 hours ago, disco_monkey79 said: Is it to do witht he aftermarket wheel boss? Ie has it moved the wheel forwards or back, relative to where the standard wheel would sit? Sounds like you may be on to this, but thought I would chime in anyway. I am 6' 7", so will be moving the seat further back, as well as changing the wheel. Stoopid legs. I think the steering wheel might sit further forward but I don't have an original for reference. Also I need to lower the seat, it's not a standard Cortina seat and I think sits a bit higher. Another thing I noticed is the pedals seem to sit offset to the right slightly compared to the steering column, which again I'm not sure is normal in the Cortinas 🤷♂️ Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 765 Posted March 13 The column pass's between the clutch & brake. Quote Share this post Link to post Share on other sites
TIB3300 455 Posted March 13 (edited) On 3/11/2026 at 12:28 PM, Stuwindsurf said: Hi, Does anyone else have issues with legroom under the steering wheel? I have a 14" Mountney steering wheel fitted to my facelift Mk3 and the only way my legs will fit under the steering wheel comfortably to operate the pedals is to let me knees fall out either side of the steering wheel which feels really odd! Is this a common thing with the Mk3's?... Are the storks close to the steering wheel and easily caught when turning the steering wheel? If the steering wheel you have is for a MK4/5 then its quite flat. Not V'ed like a MK3 Edited March 13 by TIB3300 1 Quote Share this post Link to post Share on other sites
J2S 169 Posted March 13 Are they the correct seats in it ? 1 Quote Share this post Link to post Share on other sites
disco_monkey79 33 Posted March 14 This is the distance from the metal of the dash to the face of the wheel on my MK4. I had the same issue as you are finding on my Capri (many years ago) which had a mountney style wheel. I figured it was cos it moved the wheel further back and thus reduced leg room. I intended to get a spacer ring made, but wrote the car off before I had the opportunity. Ooops. 1 Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 765 Posted March 14 The columns are different lengths so that the wheel is in the same position in relation to the dash. Quote Share this post Link to post Share on other sites
Stuwindsurf 4 Posted March 25 On 3/14/2026 at 1:01 PM, disco_monkey79 said: This is the distance from the metal of the dash to the face of the wheel on my MK4. I had the same issue as you are finding on my Capri (many years ago) which had a mountney style wheel. I figured it was cos it moved the wheel further back and thus reduced leg room. I intended to get a spacer ring made, but wrote the car off before I had the opportunity. Ooops. Thanks, I just machined up a 50mm spacer for the steering wheel and now everything is perfect 👌 1 Quote Share this post Link to post Share on other sites
