disco_monkey79 33 Posted March 22 As per the title it's time to fit the bushes to the bar and put it on the car, but... The poly bushes are one-piece, with no slit in them (I e. They are a continuous loop. I nipped one up in the wood wice, but when squished it's still too tight to get over the ring at the end of the ARB. Do I just need to be more forceful? Or should it have had a slit along the bottom, like the ones I removed? Thanks Quote Share this post Link to post Share on other sites
disco_monkey79 33 Posted March 22 Disregard - with some elbow grease, and some actual grease, they popped on fairly easily. Ta. 1 Quote Share this post Link to post Share on other sites
dgo 80 Posted March 22 Sorry just seen this and happy you've persevered and succeeded. Usually a soak in hot water first helps especially if where you are working is chilly. 1 Quote Share this post Link to post Share on other sites
