db9
mk3 pickup (bakkie) h-brake cables
any one know if the h-brake cables are unique to the bakkie
i got new front n rear( dash mount ones) but they appear to be different length
The front piece is the same as the Cortina P100 but the rear is to long ( the P100 was the mk5 LWB version 16 inches in wheel base, mk3-4 was only available in swb) bakkie is same wheel base as std model .
The bracket on the yoke of the cable is a few inches longer swap this onto a std cable & it will then work ( if it's missing you'll have to make a short piece to bridge the gap) if you're lucky you may find a rear cable here in the UK ( last one I bought was in late 90s) as a dash handbrake with bench seat was available upto early 72 on base/L model ( not 2dr) with the ohv eng.
