t.onyb
Ford Essex V6 Inlet Manifold
Hello,
I’m after an inlet manifold for my Essex V6 (Think that’s what is is called?)
Any about??
Thanks,
Tony
Yep
26 minutes ago, sheffieldcortinacentre said:
Yep
Thanks Craig
Just be aware there are 2 types one with oval ports the others D shaped get the one that has same shape holes.
Is there a way to tell them apart? Mine is still on my car - the picture is one I found on Google.
It should have a number cast in it let me check up, What's wrong with yours?
  • Thanks 1
Think oval port would be 702 , D port 722 stamped in .
  • Thanks 1
My temp sender snapped and I can’t get it out 😩
Ah, it's only brass which is soft, drill it out & then re tap the thread.
To be honest, I’m confused.
My water temp gauge has never worked. The instrument panel side works fine as does the petrol gauge.
When earthed direct all works fine but connect to the sensor all stops.
Had so many new ones from Burtons which may have be correct or not? Who knows??
So I got this one from a classic dealer but it was bigger than the others. When I say bigger, had a longer thread and looks slighter wider.
I started to fit it and it was going in quite easily then it felt tight, then snapped.
Just don’t know what’s going on.
They are a slightly tapered fit, should go about half way in. Bit after theard is about an inch long.
  • Thanks 1
So frustrating if you were nearer could probably sort this pretty easily for you.
I bet - Seems all the knowledge is miles away 😩
My loss 😵
You'll have to come retire up here, We've got indoor plumbing & everything nowadays.
  • Haha 1
Nearly bought me own drink then
Please sign in to comment
Sign In Now
