Stuwindsurf 4 Posted October 18 Im sure this has probably been discussed before, but Im looking to add electric windows to my 2 door Mk3 Cortina. I have looked around at universal kits avaliable but did read somewhere they struggle with the weight of the glass in the 2 door, especially if they are a bit tight. I don't mind modifying or adapting mechanisms from other cars but would like to know who has tried what and how successful they were please? Many thanks Stu Share this post Link to post Share on other sites
sheffieldcortinacentre 772 Posted October 18 Problem is more due to the small contact area at front end of glass in frame. It magnifies any wear in runner & causes glass to drop at front & jam up/strain motor. Best way is if you can find the setup from a pre facelift MK2 Granada ( pre W reg) or I've used Mk5/6 escort. They very similar to cortina mech, mount it 75-100mm further forward in door( not necessary in 4dr/EST) then make a bridging piece/adapter to go between the glass & mount. It's hard to describe but pretty obvious once you see it. Share this post Link to post Share on other sites
Stuwindsurf 4 Posted October 18 37 minutes ago, sheffieldcortinacentre said: Problem is more due to the small contact area at front end of glass in frame. It magnifies any wear in runner & causes glass to drop at front & jam up/strain motor. Best way is if you can find the setup from a pre facelift MK2 Granada ( pre W reg) or I've used Mk5/6 escort. They very similar to cortina mech, mount it 75-100mm further forward in door( not necessary in 4dr/EST) then make a bridging piece/adapter to go between the glass & mount. It's hard to describe but pretty obvious once you see it. Thanks Craig, just been looking at the Mk6 Escort mechs, they look straightforward 👍🏻 Share this post Link to post Share on other sites
Stuwindsurf 4 Posted October 18 Just to be sure, is it these ones? Share this post Link to post Share on other sites
sheffieldcortinacentre 772 Posted October 18 Ye that's them, some drilling & spacers to get them orientated as per original then join glass mount to the square carriage/plate. Your trying to put a slight bias so the window weight keeps the glass square to the rear of the door by moving the centre line towards the front of door. Hard to explain in words ,wish I'd got a pic. Share this post Link to post Share on other sites
Stuwindsurf 4 Posted October 18 Thanks. I think I get what you're saying, it's moving the balance point forward slightly to stop the glass tilting towards the front of the car when raised? Share this post Link to post Share on other sites
sheffieldcortinacentre 772 Posted October 18 Basically yes I'll try sort pics . I've got mech but might have to demonstrate with a different window. Share this post Link to post Share on other sites
