madmaxptt
Photos from Under the engine
Hi!
I am looking for some pictures with pinto engine installed in a Ford Cortina MK3/4/5 engine bay but under the engine.
My mechanic made a custom oil sump (modified an alloy from pinto to increase oil capacity and I think that its not going to fit, I am afraid foul with Cortina's front crosmember.
I want some photos from the side of the inlet but under the engine or the side of it to see how much space is available on this side.
Trying to think of I've got any. Bigger problem could be starter clearance , or is that a LHD bell housing?
  • Like 2
Sorry about the state of it lol
scrapping along the floor and oil leaks part of the charm for me  just under 10k in it this year
On 11/5/2026 at 9:19 AM, madmaxptt said:
..........modified an alloy from pinto to increase oil capacity
Can I ask why ?     I'm thinking if the capacity is more then you can go longer between oil changes...but when you come to change it'll cost more?.......if it's a cooling thing, why not just add a cooler?
.....or if it's just for why not then fair enough !
:thumbsup:
Now it takes upto 5,5 lt because I have fitted high pressure high capacity oil pump and I want always to have some oil in my oil sump (to avoid oil starvation)
Please sign in to comment
Sign In Now
