doozer 0 Posted May 25, 2009 Hi guys, I'm sure this has come up many times But I'm after a rear disc brake conversion for a 2l mk3 Can anyone help? Cheers Doozer Share this post Link to post Share on other sites
sheffieldcortinacentre 774 Posted May 25, 2009 use a sierra handbrake cable (disc brake type)sierra/granada rear calipers (non vented type) escort/capri mounting kit & can't remember if its mk2 fiesta or mk3-4 escort solid frt discs. Share this post Link to post Share on other sites
V8IAN 0 Posted May 26, 2009 Yep. Ugly Scorpio/Gramada and some seirras calipers, Non vented are easy to find, but Cosworth variants of Scorpio, Escort and Sierra have vents. also the Mk5/6 RS2000 Escort, There are other options for callipers, with the late VW/Audi callipers being a good choice as they are alluminium, and another, which are getting hard to find are Citroen BX Fronts, as they have the handbrake on the front wheels, You can buy a kit from Rally Design for fitting the callipers, which look as if they are bolt on brackets, BUT must be welded to the axle, Discs, Choice of 2 types really, Fiesta Mk1/2, or mk3 escort 1.3, the escort is my preference as they have a bigger offset and move the calliper away from the wheel allowing better clearance for wheels, and also has the added benefit of allowing the brackets to be further away from the flange of the axle which affords more room for welding Half shafts, Its not as straightforward, as the shafts have to have about 3mm turned off the dia to allow the discs to fit,. Handbrake levers are best pirated from the original disc braked car, as the lever ratio is different, Cables, Sierra ie one, or possibly the Escort Cosworth/RS2000. Master Cyls, Not sure what to suggest, I know how I did it, I used a master cylinder from a car with a similar brake setup to what I was fitting to my car, I used a cylinder from a 5 series BMW, but I would think the cylinder from a Disc braked Sierra would bolt onto your Servo and be about right for displacment, Share this post Link to post Share on other sites
doozer 0 Posted May 26, 2009 Yep. Ugly Scorpio/Gramada and some seirras calipers, Non vented are easy to find, but Cosworth variants of Scorpio, Escort and Sierra have vents. also the Mk5/6 RS2000 Escort, There are other options for callipers, with the late VW/Audi callipers being a good choice as they are alluminium, and another, which are getting hard to find are Citroen BX Fronts, as they have the handbrake on the front wheels, You can buy a kit from Rally Design for fitting the callipers, which look as if they are bolt on brackets, BUT must be welded to the axle, Discs, Choice of 2 types really, Fiesta Mk1/2, or mk3 escort 1.3, the escort is my preference as they have a bigger offset and move the calliper away from the wheel allowing better clearance for wheels, and also has the added benefit of allowing the brackets to be further away from the flange of the axle which affords more room for welding Half shafts, Its not as straightforward, as the shafts have to have about 3mm turned off the dia to allow the discs to fit,. Handbrake levers are best pirated from the original disc braked car, as the lever ratio is different, Cables, Sierra ie one, or possibly the Escort Cosworth/RS2000. Master Cyls, Not sure what to suggest, I know how I did it, I used a master cylinder from a car with a similar brake setup to what I was fitting to my car, I used a cylinder from a 5 series BMW, but I would think the cylinder from a Disc braked Sierra would bolt onto your Servo and be about right for displacment, WOW what a response thanks loads for that guys Doozer Share this post Link to post Share on other sites
costina 3 Posted May 26, 2009 The sierra master will not fit the cortina servo,you will need a sierra servo aswell then you will have to mod the bracket and actuator rod once you have the bits its easy to mod Paul Share this post Link to post Share on other sites
