colin14 0 Posted September 29, 2012 2 x koln rear axles, believe they came of a mk3 2.0 gt, 9'' drums possibly 3.89 ratio, been sitting a while so needs bushes/brakes renewing, both turn freely although 1 has bit more play than the other £25 each front subframe. all complete with steering and arb apart from hubs which i removed for project but available for extra cost, all bushes/balljoints need replacing £20 bare front subframe, no arms/wishbones just pure bare frame £10 pair of front hubs stub axles with calipers, brakes will need rebuilding £45 mk3/4 pedal box, non ratchet type complete with new clutch cable £20 brand new 2.8 v6 3pc 240mm clutch kit with flywheel. got fitted on engine started up and removed again because engine was scrap £50 collection only from milton keynes. 07564998695 Quote Share this post Link to post Share on other sites
wolfrace 116 Posted September 30, 2012 (edited) I would like the subframe i'd rebuild that to install in place of mine. I just need to organise pick up, unless another member is heading in bath/Bristol direction from your way and doesn't mind dropping it off for fuel money. It's the one with the arb rather than the bare one i'm after, my current one is pre facelift and has no arb. Edited September 30, 2012 by wolfrace Quote Share this post Link to post Share on other sites
buzzard 13 Posted September 30, 2012 im intrested in the axle . im after a 3.89 ish axle . Quote Share this post Link to post Share on other sites
colin14 0 Posted September 30, 2012 both axles are 3.89 ratio, would say blueish axle is ideal for spares as teeth are bit rusty in side but all moving as it should. also got another steering rack and small antirollbar if any intres for them Quote Share this post Link to post Share on other sites
buzzard 13 Posted September 30, 2012 hi . im very intrested in one of the axles . i will see if i can find some time this week or weekend to pick mit up .is the a time preferance that suits you . cheers paul . im only in kettering Quote Share this post Link to post Share on other sites
Dickyboy 0 Posted October 3, 2012 Definately interested in clutch kit if the flywheel is with it Quote Share this post Link to post Share on other sites
colin14 0 Posted October 5, 2012 Flywheel with it aswell as the bolts, pressure plate,clutch plate and bearing. Thanks Quote Share this post Link to post Share on other sites
wolfrace 116 Posted October 5, 2012 Sorry it's taken a while to get back to you, I've been trying to find out when I can collect. I could pick up the front subframe (the one with all the ancillaries) next weekend if that suits you? Rich Quote Share this post Link to post Share on other sites
colin14 0 Posted October 7, 2012 complete subframe now sold and collected. thanks Quote Share this post Link to post Share on other sites
colin14 0 Posted October 20, 2012 blue rear axle, bare x member and clutch just left now Quote Share this post Link to post Share on other sites
