norton 82 Posted March 11 (edited) i checked the number on the bottles and there was none on the DOT 4 and the correct number as per Haynes on the DOT 3. i've a bit of a nagging doubt though..... is DOT 3 right? the Interweb tells me " Ford recommend DOT 4 " but that's for modern cars I assume. I've no idea whats actually in the car of course. Edited March 11 by norton Quote Share this post Link to post Share on other sites
Deano66 205 Posted March 11 Hi Norton,you've probably got DOT3 in your car,the only difference between DOT3 & 4 is that DOT4 has a higher boiling point.You can add DOT4 to DOT3,but not DOT3 to 4. Quote Share this post Link to post Share on other sites
norton 82 Posted March 11 2 minutes ago, Deano66 said: Hi Norton,you've probably got DOT3 in your car,the only difference between DOT3 & 4 is that DOT4 has a higher boiling point.You can add DOT4 to DOT3,but not DOT3 to 4. thanks for that. i don't think the fluid has been looked at for years, so I was assuming it was DOT 3 . The reservoir was nearly empty, first time on the road this weekend, so just as well i checked. I have a new DOT 4 botttle, so good to know I can use that, and use DOT 4 going forward. When i get a round tuit , i'll change the fluid completely. Quote Share this post Link to post Share on other sites
sheffieldcortinacentre 532 Posted March 11 Yep you can put higher number in without probs, just don't mix silicone fluid with mineral. Quote Share this post Link to post Share on other sites
Tigdlo 26 Posted March 11 If the fluid has been in there a long time, it’s probably mainly H2O! I would suggest changing it asap. Quote Share this post Link to post Share on other sites
norton 82 Posted March 12 15 hours ago, Tigdlo said: If the fluid has been in there a long time, it’s probably mainly H2O! I would suggest changing it asap. it was so empty, it's now mainly brake fluid. The next bleeding will shift a lot of what's still there, never seen a car so empty, I hope the previous owner didn't skimp anything else! Quote Share this post Link to post Share on other sites
