Pete-H 66 Posted December 30, 2017 This will sound really stupid, but check all of the earths, make sure none are corroded, loose or damaged as that may cause a problem for the engine to earth to the body and that only shows up when wet. Quote Share this post Link to post Share on other sites
TreeBeard 1 Posted December 30, 2017 Thanks Pete H, Ill have a look Ive the earths tomorrow Quote Share this post Link to post Share on other sites
sierra3dr 36 Posted December 30, 2017 check see if that wire hasn't fallen. Mine runs crap when it dislodges itself. I also have the accuspark on mine,runs a treat. Never had to by pass the ballast. As we know,ballast systems are 9v. What's the fuse-box connectors like,in good condition? 1 Quote Share this post Link to post Share on other sites
martog 128 Posted December 31, 2017 Might be worth popping the bonnet on a wet night and looking to see if you can spot any arcing going on around the dizzy cap / leads etc... Don't use a torch and look at the engine from the side of the car to minimise any risk of clothing catching on any rotating parts etc. Quote Share this post Link to post Share on other sites
Cortina1975 28 Posted January 5, 2018 (edited) Could be a crack in the distributor cap or rotor that's arcing when it gets wet if it's the original. Some HT leads I have used have given problems as the boots don't fit the terminals tight enough and let in moisture. Magnecor are pricey but seem the best. Are you sure the polarity of the coil is correct...if it's reversed the output will be low and show up any weaknesses in the system. Edited January 5, 2018 by Cortina1975 Quote Share this post Link to post Share on other sites
TreeBeard 1 Posted January 26, 2018 UPDATE. After far too much messing about and replacing things i took another look at the rotor arm, turns out the one i put in from the electric starter kit was a tiny bit shorter than the original one... DUH! Swapped it back for the old one and it now runs perfectly, 6 months of banging my head against a wall for nothing haha Quote Share this post Link to post Share on other sites
dgo 66 Posted January 26, 2018 Well a painful lesson but it's sorted and should run nicely now given there are one or two new parts fitted :thumbup: Quote Share this post Link to post Share on other sites
