sheffieldcortinacentre 532 Posted May 12, 2020 Probably had wrong starter gear, the inertia type had a 9 & 10 tooth version & must be fitted with the correct ring gear ( two different amounts of teeth dunno number but was a common fault back on the day). 1 Quote Share this post Link to post Share on other sites
chris mk3 313 Posted May 12, 2020 Yes its been reet chewed up on two sides Quote Share this post Link to post Share on other sites
Cortina1975 28 Posted May 12, 2020 Hat tip that body is looking really solid ,it's good to see another XL getting restored 👍. 1 Quote Share this post Link to post Share on other sites
Deano66 205 Posted May 13, 2020 Good work on the door Chris, flywheel looks a little worn !!!! Quote Share this post Link to post Share on other sites
chris mk3 313 Posted May 13, 2020 (edited) Cheers lads, yes the flywheels been attacked, like Craig said maybe the wrong starter gear, bit more done today, finished a little welding on the quarter, then little skim of P40 over the welds, then the filling/blending task which i quite enjoy, its going to be hard to get the wheel arch flare right, im pretty sure the rears dont flare out as much as the fronts. Trial fitted the secondhand new wing, fits a treat, im leaving it on as its inspiring me to keep pushing on Edited May 13, 2020 by chris mk3 2 Quote Share this post Link to post Share on other sites
V6Ghia 33 Posted May 13, 2020 Great progress, it is good to look back at where you started from, fantastic work. 1 Quote Share this post Link to post Share on other sites
GhiaMk4/5 206 Posted May 13, 2020 There's no stopping you, looking brill!! 1 Quote Share this post Link to post Share on other sites
Pete-H 66 Posted May 14, 2020 That looks good not sure about the colour coded door handles though? 1 Quote Share this post Link to post Share on other sites
John Mack 249 Posted May 14, 2020 3 hours ago, Pete-H said: That looks good not sure about the colour coded door handles though? 1 1 Quote Share this post Link to post Share on other sites
J2S 129 Posted May 15, 2020 15 hours ago, John Mack said: I don’t know I like satin black on the handles and round window frames chrome so 70’s Quote Share this post Link to post Share on other sites
FKLGLS 43 Posted May 16, 2020 Brilliant work. Quote Share this post Link to post Share on other sites
GhiaMk4/5 206 Posted May 16, 2020 Is it painted yet, not taking the pee, having seen the speed you work at !!!! Quote Share this post Link to post Share on other sites
John Mack 249 Posted May 16, 2020 1 hour ago, GhiaMk4/5 said: Is it painted yet, not taking the pee, having seen the speed you work at !!!! Could be on the road !! 1 Quote Share this post Link to post Share on other sites
chris mk3 313 Posted June 6, 2020 Hi guys, not to dwell, getting a divorce,( 14 years was a good effort!) so Cortinas back at my moms ,hence no updates . Work is still continuing, as nothing will stop the progress on the Cortina, ok news flash over. Bought a new black Vinyl roof from Aldridge trimmers, nearly finished the welding, headlamp surrounds to finish and a chassis repair left to do, front panel, and rear valance are now welded on, ive been etch priming and seam sealing the new welds, next ill be starting on the engine bay, removing surface rust, and general clean up, 5 litres of filler primer bought to throw on the bodywork, this will be done before summer has been and gone, my main concern is to get any bare metal covered, with life being a little in limbo, i have to make sure the Cortina is weather ish proof, incase i lose my current storage, this all adds to my Cortina story, if they can build Spitfires during WW2, i can finish the Cortina during a little life wobble ! 2 Quote Share this post Link to post Share on other sites
GhiaMk4/5 206 Posted June 6, 2020 Sorry to hear about your hiccup in life, can't live with them and can't live without them, BUT they take some sussing out, mine always thought I would change, I probably have got worse, as you get older you seem to have more disposable income, more parts to buy and more cars!!!! 1 Quote Share this post Link to post Share on other sites
